July 11, 200718 yr Hey guys, A fuse which i think is for my A/C compressor keeps blowing. W/o fuse, air wont be cold. Pop a new fuse in the fuse box, and it may work for a few mins and it blows again. Any input on past problems you've had, or things to check, such as wires to trace?
July 11, 200718 yr the is a bank or felays on the passenger side firewall near the vacuum canister that is AC related. inspect the wires around that location
July 11, 200718 yr Also look behind the glovebox and make sure the that the wires to the pulser unit are not crimped or damaged, also look at the wires going to the Compressor. Otherwise, perhaps the there is a part failing, like the pulser, or the magnetic clutch in the compressor.
