Gyoas759 Posted July 17, 2007 Share Posted July 17, 2007 I currently have an 83 GL wagon with an EA82 engine in it. The exhaust I have on it has both cats and then a cherry bomb. It wont fly with PA inspections. I saw an EA82 gen GL wagon in the local Pick n Pull that has a good exhaust on it. I know the exhaust will mount up to the existing one, but I'm not sure on the body shape. I plan on lifting the 83 soon, so I want the exhaust to fit in tight with the body. Anyone know if the exhaust between an 83 and 87ish are the same? Trying to figure out if I can use it or if I need to make one custom. Link to comment Share on other sites More sharing options...
86BRATMAN Posted July 17, 2007 Share Posted July 17, 2007 I've not actually side by sided the two. but the cars are within a half inch of wheel base. It shouldn't be too big a deal. Link to comment Share on other sites More sharing options...
MilesFox Posted July 17, 2007 Share Posted July 17, 2007 the mid pipe will fit most part. the y pipe afterall is ea82. the muffler half may be different but if you get the whole pipe from yhe y flange back it will run correctly along the body. the rubber mounts may be in the wrong place you may have to get creative Link to comment Share on other sites More sharing options...
