July 22, 200718 yr I am upgrading my 80' brat and soon my 80' wagon to a webber carb. I really do not know much about the carb itself. Which one should I be in the market for. that will give me the best performance. 32/36 DGV A5 (manual) 32/36 DGEV (electric) 32/36 DGAV (water) 32/36 DFEV (electric/reverse)
August 5, 200718 yr I agree, I had electric on both mine. From my experience on an EA81 (gen 2) the 32/36 DGEV worked the best. (My brat came with a carter/weber so I had to swap to the hitachi manifold, but kept the stock wiring and throttle cable) On an EA82 the 32/36 DFEV works the best because the choke HAS to be in the back.... otherwise it hits the power steering pump (if you have it) The DGEV had to be turned backwards which created throttle cable issues, so I just got the DFEV.... worked quite well til I blew the engine. Since you are gen 1 likely the DGEV is the way to go... though I never have converted a gen 1.
