August 2, 200718 yr I'm repairing the inevitable rust on my 96 Subaru Legacy. The rear door has rusted under side trim/ door moulding where the clips go through the body. I've removed the trim which was held on both by clips and double sided foam tape, and repaired the damage with Bondo and Tiger Hair. The clips are all broken and I'm inclined to not put new holes in the door as that is how the rust got a foothold. Does anybody have suggestions on a good adhesive to just glue the trim on? I'm thinking about some sort of construction adhesive but don't know how it will hold up.
August 2, 200718 yr Try some 3M 847. We use it at work where we call it gorilla snot and works well in many applications.
August 2, 200718 yr Author Try some 3M 847. We use it at work where we call it gorilla snot and works well in many applications. Thanks....it looks like the same stuff I used when I replaced the glass in my outside mirror(?)
