85glsw Posted August 4, 2007 Share Posted August 4, 2007 Anyone hazard a guess if '88 DL 4wd front strut would fit on an '85 GL 4wd? I just want to switch one strut, because the crown bearings are going bad. Maybe better I rent two spring compressors and swap the crown bearings? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 4, 2007 Share Posted August 4, 2007 Anyone hazard a guess if '88 DL 4wd front strut would fit on an '85 GL 4wd? I just want to switch one strut, because the crown bearings are going bad. Maybe better I rent two spring compressors and swap the crown bearings? The strut will physically bolt in. But it is not a good idea to change just one strut. Especially changing spring just one spring with it. If you are going to swap, swap both struts. Renting a spring compressor, and just changing the upper mount/bearing on you're existing strutis a good idea too.(plus then you keep the height adjustable struts) In that case it would be OK to do just one. Quote Link to comment Share on other sites More sharing options...
85glsw Posted August 4, 2007 Author Share Posted August 4, 2007 The strut will physically bolt in. But it is not a good idea to change just one strut. Especially changing spring just one spring with it. If you are going to swap, swap both struts. Renting a spring compressor, and just changing the upper mount/bearing on you're existing strutis a good idea too.(plus then you keep the height adjustable struts) In that case it would be OK to do just one. Thanks. That's what I was afraid of. Quote Link to comment Share on other sites More sharing options...
