August 16, 200718 yr Hi, I am interested to do a 5 lug swap on my gl-10, it is a 4x4 with disc brakes. Can I just take the big nut off and put the 5-bolt hub flanges on, or is it more involved than that? I know some of you have done this and know the drill. I want to know what is involved before I start so maybe I won't have surprises and delays once started. Thanks all
August 16, 200718 yr http://www.ultimatesubaru.org/forum/showthread.php?t=50400 Pretty much covers it.
August 16, 200718 yr Can I just take the big nut off and put the 5-bolt hub flanges on You would take the big nut off, pull the flange, take it to a machine shop, and get whatever bolt pattern you want. But most folks do the whole hog type of swap with the improved braking, front alignment options, and updated struts. Your choice.
