September 8, 200718 yr hi I was just wondering how much you can adjust the suspension on a Brat, what are side affects of adjusting the suspension and is it worth it? When i finally find a Brat it would be off road all the time.
September 8, 200718 yr I have an '86 Brat GL. The front adjustment will give you about 1.5" of additional height. There are two nuts and bolts on the bottom of the upper front strut mount that raises the upper coil spring bracket. It seems to add more negative camber, but not so much that a good alignment can't offset.
September 8, 200718 yr Author thank you for the information, the front is the main part which would need to be done. Does anybody know about the rear, how much it can adjusted by and where the bolts are?
