December 10, 200322 yr I swithced the block and manifold, I have had a problem with my grounds and that seems cleared-up. For some reason my fuel pump stopped working? I got a new disty cap and rotor and new plugs. I have 24 to 25 volts coming out my secondary on the coil and that is grounded and the secondary to case has a resistance of infinity, so the coil should be good. I still have no spark I forgot to check the four lines to the disty, I'll go do that.
