December 10, 200322 yr Has anyone ever had a code 9 on self Dianostics for the air shocks systems.It is suposed to be the compressor relay.Could this cause the system to deflate in all different config,front one time then the rear the next.Robby
December 10, 200322 yr Do you know if there is more then one relay? If there's only one relay for the compressor, I would assume you just wouldn't get air, and the whole car would deflate/lower.......unless there's some check valves somewhere that alternate being open and closed......not sure though.
December 15, 200322 yr Author I don't if there more.If I leave it inthe Hi postion it takes two days to lower,but just the front. If i leave in the normal postion it lower in the rear in about twenty minutes. Robby
December 15, 200322 yr hmmm....that is very bizarre. may want to ask this question over the legacycentral bbs. http://www.bbs.legacycentral.org there's some guys over there with more experience on air susp then myself.
December 16, 200322 yr I don't know much about the air system. That's why I converted. I you are interested I have 2 brand new front shocks and 2 good original rears and the whole compressor which works fine(turns on and pumps) the problem was that the car would get stuck all the way up and could not be lowered. I know it was probably just a solenoid on the dump side but I just bought the car and didn't want to mess with the system. If you are interested I would be willing to entertain offers on any or all parts.
December 16, 200322 yr Author How much do you want for all of it?Do you have the controller?Where are you located? Robby in NC
