'97 Ford Explorer Timing Belt
Does anyone know if the engine on a '97 Explorer is non-interference or interference? I see a Craiglist local here but I believe the timing chain/belt is broke. If the engine is non-interference, I might buy it and fix it. If it is interference, then I'm not going to bother with it.
Thanks...
you can look it up on the internet. i think gates, the timing belt manufacturer, has a comprehensive list that i use. calling a Ford dealer would obviously give you what you need as well.
