86 Turbo ECM?
How do I know if the ACM is Bad . to Make the car run I Ran a hot wir to the fuel pump. It ran real well. I bought the car not running. Well I finally found the ECM under the rear shelf.in the trunk. Before I reassemble the complete interior I'd like to Know if its the ECM or something else thats causing the original problem. I also Can't find the fuel pump relay. It would help if I knew what it looked like.
Thanks Dave
