questions for pulling heads on 98 obw
Hi, I need to pull the heads for my 98 obw to do a valve job, do you guys recommend pulling the entire engine out or leave the engine in? I am also doing timing belt/water pump, too, I guess if i pull the engine then the clutch can be done as well.
any recommendation greatly appreciated!
I tried to find a write up on this and had no luck, any suggestions?
Thanks alot!
wow, that helps alot, thank you!
