January 10, 200818 yr Hello All! Ok, so my question is where the HELL is the harness for the O2 sensor? I had to swap on a new y-pipe the other day. OLD Y-pipe: O2 not hooked up Converter was gutted Car ran well NEW Y-pipe: Have no idea where to hook up O2 Cat is in great shape Car stumbles and rans not so well There is a harness connector that close to the cat but the connctor is not similar to the one on the O2. The O2 has a wire lead coming off of it. The harness connector appears to be a push on style. Would you guess that to O2 is a universal aftermarket item and I just need to splice it into the existing harness? Thanks!
January 10, 200818 yr Would you guess that to O2 is a universal aftermarket item and I just need to splice it into the existing harness? Thanks! That's what I would say, the O2 connectors are usually a blade type connector. The Female end is on the car side and the male is on the sensors side, at least that's how it was on my GL-10
