jeddy Posted January 17, 2008 Share Posted January 17, 2008 I was wondering if it would be worth building a buggy out of a wrecked '99 2.5 Impreza RS coupe. The drivetrain is still good, just mangled the front sheet metal, lights, etc. It's an automatic, which I didn't want, so is that bad for off roading (not in general, just from a Subaru stand point)? How does the transfer case work on the RS models? Can you put lockers in them? Any one know what gearing it would have? I don't know anything about these because I was hoping to use an older (mid eighties) car or wagon for the buggy, but I could pick this car up pretty cheap (probably around a grand). If anyone has any info, tips, or reasons why I should or should not pursue this please let me know, or if you know of any links please post them. Also, I read the sticky, but didn't find the info I was looking for. And this won't be my first soob, have had a Brat and a Loyale. Thanks, -Jed Quote Link to comment Share on other sites More sharing options...
bluebaru Posted January 28, 2008 Share Posted January 28, 2008 are you thinking about buying the one on craigslist in central missouri. I have actually been thinking about that same project... Quote Link to comment Share on other sites More sharing options...
bluebaru Posted January 28, 2008 Share Posted January 28, 2008 No lockers and no transfer case. the subaru case is actually in the tranny. i would leave the tranny because the 4eat isnt the best for off-roading but its better than most. also you can wire in a center diff lock switch to make it 50/50 torque split which is nice. the gearing should be ok for a buggy because the car will the lighter and the car already has lower geared diffs than the older subes do. the engine will have the proper power to really turn a larger tire. Quote Link to comment Share on other sites More sharing options...
