Alignment specs for 98 GT wagon?
The car will be used for normal driving with some track and auto cross time. Everything is stock except for the KYB GR2 strut upgrade.
Any suggestions?
-1.0 deg camber front & rear. 0 toe front & rear.
You may not be able to get that much camber, or may have more in the rear. Depending on how good the tech is, he should be able to loosen some of the bolts and get things to where they need to be.
for track and auto-x you want at least -2 degrees of front camber. A second set of bolts or plates would be necessary for that.
