1981 brat swap questions.
has anyone put an ej22 with a gen 1 dual range trany. id like to put an ej22 in a 1981 brat but want to keep the orignal trany. anyway thanks for the help in advance.
The 81 Brat tranny is the same as any other EA81 4 speed D/R.
Adapting the EJ22 to it should be as simple as drilling the EA81 flywheel and using the commonly availible adaptor plates that folks sell.
so the 4wd low linkage is the only thing differnt about the 1981 ea81 trany?? huh would have figured it was more then that...
Actually even that is the same - it's just rotated 90 degree's. I put an 81 Brat tranny into an 82 Brat. You have to rotate the 4WD bit, but otherwise they are identical to any other 81/82 4 speed D/R.
