P0303 Cyl#3 misfire HELP!
Wow, that's a really great job of diagnosing and fixing the problem, Mark.
Just one question, had you noticed an abnormally high rate of oil consumption as a result of the bad exhaust valve?
Not really. It wasn't using a lot of oil, but I wasn't driving it all that much. The primary problem was loss of power and a horrible shake at idle. The rear separator cover was leaking too, made things a little messy under there.
