March 16, 200818 yr I need to remove the headliner on my '99 Impreza wagon. Is there a way to drop this without having to remove all of the interior's plastic side trim? Sure would save a lot of time if I didn't have to remove all of the extra interior trim. Anybody got experience removing Subaru headliners? Thanks for any help!
March 16, 200818 yr what i can tell you is that subaru headliners (at lest in my 96 legacy) are alot like the cover for the rear deck.....and the way i got that out was just kind of prying on it.....i assume you could give that a try.......what are you tryin to get it off for anyway?.......
March 16, 200818 yr you wouldn't by any chance be trying to fix a leaky rear window washer would you? It's likely in the drivers side RUBBER JOINT - the pipe (hose) has gotten stiff and cracked. Pull out the rubber cover and fish the hoses out, go get a couple of connectors and a piece of rubber vac hose and plug it all back together. Didn't try getting out the headliner, though
March 16, 200818 yr Author you wouldn't by any chance be trying to fix a leaky rear window washer would you? Nope--I've got a big dent in the roof, so I gotta remove the headliner so I can do a little gentle pounding. I ended up loosening one side of the interior trim and that gave enough room to slide it out from the other side. I hate taking interiors apart because I can never do so without crapping out half the plastic clips that hold everything in. Thanks for the input.
