March 20, 200818 yr My wife's 04 obw has just had its first code. it is the p0483 cooling fan rationality check. Any advice on what to look for? How about a trick to get the relays out of the clips they are in? (two screwdrivers??) this car only has 52k on it btw. is this a warranty-covered issue? thanks for the attention . Pat
March 20, 200818 yr Well, First do the Fans cycle on? Check for some loose connections and 2 screwdrivers should work to get those clips out, Im asuming that the clips are those black wrap around ones with the 2 wedges that stick through the metal?
