March 27, 200818 yr What years of the 2WD automatic will fit the EA-81 engine. Need something that dosen't require an ECM or additional wireing. Thanks, Cawain
March 27, 200818 yr all of them the ea82 trannies will fit but the rear mount is a little bit different. you can adapt the rear mount with minor fabbing .other than that they are the same in design, the pump shafts, governors and torque converters are interchangeable between ea81 and ea82, fwd and 4wd 3spd at's if you are replacing the trans due to shifting problems, check the governor as it may be your problem. do some searching for "governor shaft" somewhere there is an article on how to service it.
March 28, 200818 yr Author Johnson']What are you putting it in? I will be puting it in a trike and modificationas are not a problem. Thanks, cawain
