DeSubiefan Posted April 7, 2008 Share Posted April 7, 2008 The ABS pump on my 95 Legacy L wagon is leaking brake fluid from the weap hole. I don't really care about the ABS not working since I unplugged it months ago because the relay kept running. I just wanted to see if anyone has suggestion less costly than buying a new unit @ $1100. I have posted for the part over on the Market Place board and I have gotten one promising response. But wanted to throw it out for comments here to see if anyone has an idea. Can you just bypass the whole unit? Quote Link to comment Share on other sites More sharing options...
hankosolder2 Posted April 8, 2008 Share Posted April 8, 2008 The ABS pump on my 95 Legacy L wagon is leaking brake fluid from the weap hole. I don't really care about the ABS not working since I unplugged it months ago because the relay kept running. I just wanted to see if anyone has suggestion less costly than buying a new unit @ $1100. I have posted for the part over on the Market Place board and I have gotten one promising response. But wanted to throw it out for comments here to see if anyone has an idea. Can you just bypass the whole unit? I think you could bypass the whole unit. You would probably need two T fittings (i.e. I think it has one "front" and one "rear" input from the master cylinder, and 4 outputs -one for each individual caliper.) Of course, there may be some insurance / liability implications of doing that. Your car, your decision. Nathan Quote Link to comment Share on other sites More sharing options...
lmdew Posted April 8, 2008 Share Posted April 8, 2008 I have a good one, $75 plus shipping, about $40. Lmdew@hotmail.com Quote Link to comment Share on other sites More sharing options...
