EA82 Gas tank into EA81
I have my 86 Brat that I'm finally going to get running in the next month but was wondering since I'm going to be going SPFI in it later, will the SPFI fuel tank fit in the stock location on my Brat since my friend has on in his parts car. I'll be lifting it 4 inches anyways if it matters
No the bolt pattern is different, it doesnt have a dimple fo the rear diff and the lines and senders are different.
Compatible with your 86 Brat is:
82-87 Brat
80-84 Wagon 4wd
81-83 Coupe 4wd
82-84 Sedan 4wd
The hatch tank wont work either. It is smaller and shorter front to back.
A tank from an EA81 turbo car or brat would have the baffled tank you need.
Otherwise plan on installing a surge tank, or just always having more than 1/2 a tank full.
Joy, I'll have to start looking around for an EA81T tank and see what I can do.
