January 4, 200422 yr I think it the relay right above the fuse box.. Unscrew the fuse box and its right there.. to be sure, do a search for rear*defogger*relay
January 4, 200422 yr Author I did the search earlier and it did not help, I have found 4 relays in a line above the fuse box,and I have a empty socket near the fuse block that looks like a relay may go there. A new question I have is where is the rear defogger timer located at? Joe
January 6, 200422 yr Author Once you push the buttom for the rear defogger it stays on for set time before turning off, it is in the wiring diagram but i do not know its location. Joe
