September 4, 200817 yr Author Hi Kenny This is Jerry, that will be ok with me. Just give me a call. Thanks Jerry Jerry, Looks like the best way is to cut the frame just in front of the tcase cross member leaving that intack. Is that what you found as well?
September 5, 200817 yr Hi Kenny This is Jerry, yes thats what i did and i had to add 13 inches so the wheels will fit in the wheel wells. Thanks Jerry
September 5, 200817 yr Author excellent, thats the same number I came up with as well on first measurement, but was going to check it. Roughly how long does that make the driveshaft between the transmission and tcase? Did youd leave the sammy fuel tank? I haven't checked clearance on it, but am tempted to leave it there and plumb it in to have dual tanks.
September 5, 200817 yr Hi Kenny This is Jerry, my hatch is a 86 front wheel drive and i use the stock tank from my hatch that way the fuel gauge would work. Come on down and see it. Thanks Jerry
