November 18, 200817 yr I'm changing the horn. Is there already a relay in the circuit? By the way, this car came from the factory with just a single dinky horn. It's located next to the ABS pump, right forward.
November 20, 200817 yr I believe there should be a relay. However if you're upgrading to bigger horns, you may want to run a line from the battery and use a separate relay so you have less voltage drop.
