Check engine light
Greetings, USMB is a tremendous resource. Very good help, Thank you!
I have been going around the bend on this one. Still have Check engine light on. 1989 GL wagon turbo full time all wheel drive.
Disconnected battery to clear CE light. I get 0 long flash, 1 short flash. Haynes manual said it is Designation codes MPFI systems code 01 (MT, 49 States and Canada vehicle.) I dont know what this is telling me.
I still have a random miss during idle that, sometimes shows up as slight miss or rough at idle.
pull the plastic cover down that is above you knees when driving
find the black connectors (two single wire -one male one female)
by the ECU
Plug them together, turn the key to run (do not start the engine)
watch the small
round hole on the end of the ECU facing you
and read the codes.
Note this hole and it's LED is what is called the O2 monitor
see this site - do not be fooled by the opening line about OBD II
The site is for OBD I like you have.
http://www.troublecodes.net/Subaru/
hope this helps
