Wheel hub!??
Hi I need a new wheel hub, and junkyard has a couple of subaru's from the 80's, they dont specify, they just say they are 1800's, I was wondering what models and years would have the correct wheel hub for my 84 GL wagon 4X4? I'll attach a picture of the hub. Hope you guys can help me out with this!
84 GL wagon will be an EA81 vehicle. you can search here to figure out what vehicles are EA81. the wagons changed to EA82 in 85 or 86 but the hatches retained the EA81 until 88 or so. that's all i got. i think most, if not all, brats will work.
hmm ok thanks, I guess I'll have to go there and see...hope they have it!
Hubs off the ea82's will work. Take the old one with you.
the axle nut musta come loose on that one
-Sam
Hey so I went to the junkyard and guess what i found?? Another 1984 subaru GL wagon!! So I got the hub and two washers AND wheel caps for 13 bux...not bad at all :clap: Now all i need is a spring pin (AHHH cant find it at any standard places) A tie rod end and a ball joint...and possibly new wheel bearings.
PIX:!
