December 5, 200817 yr hi im new to this site, i have a 84 brat gl with a 4 inch lift and with a 4 spd dual range transmission and a 1.8 liter. I found a ej22 from a 91 legacy i believe. i was wondering if anyone has a list of the parts i need to do this swap, i plan on buying the adapter plate, what else do i need to do this swap?? do i need a ecu or wiring harness or can i splice it in? a complete list would be greatly appreciated.
December 5, 200817 yr there is a bunch of info if you search in this forum.do a little reading.this is a question that is turning into "one of those questions" cheers, brian
December 5, 200817 yr Hey there: Read the stick just two posts up from this. Its got the whole write up for the swap. I have an 84 brat with the ej22 motor. Much more fun to drive! I would recommend getting a whole legacy and go from there. find the ea2ej pdf and read the whole thing. It will tell you everything you need to know. Good luck. Daniel
December 6, 200817 yr Author sorry for not looking more thoroughly, i appreciate it, ill post up some pics of the brat soon so you can see what im workin with. thanks -miles
