howards11 Posted December 7, 2008 Share Posted December 7, 2008 Does anyone have an idea on how to add an intermittent wiper to the REAR wiper of a 2000 Forester L ? The rear window hardly ever gets wet enough for constant use of the wiper and I have to keep shutting it off and on by hand. Thanks in advance for your help. ~Howard Link to comment Share on other sites More sharing options...
BruceyWV Posted December 8, 2008 Share Posted December 8, 2008 I know the mechanisms are actually in the wiper assembly on mine, as its just a matter of swapping stalks to go from 3 speed wipers to intermittent. If you can find a wiper assembly from a similar forester with rear intermittent, it SHOULD be a simple swap in. Link to comment Share on other sites More sharing options...
howards11 Posted December 9, 2008 Author Share Posted December 9, 2008 I know the mechanisms are actually in the wiper assembly on mine, as its just a matter of swapping stalks to go from 3 speed wipers to intermittent. If you can find a wiper assembly from a similar forester with rear intermittent, it SHOULD be a simple swap in. I swapped out the control for the front which has the has the switch for the intermittent rear. The front now has variable intermittent but it did NOTHING for the rear. I think it's missing the electronics for the rear intermittent. ~Howard Link to comment Share on other sites More sharing options...
kami333 Posted December 9, 2008 Share Posted December 9, 2008 I have a Forester stalk with the rear intermittent position on my Impreza but it doesn't work either. From what I've read, cars with rear int have additional wiring and a relay, and they aren't easy to add. link to NASIOC thread, they talk about rear int near the bottom Link to comment Share on other sites More sharing options...
