December 18, 200817 yr Ok so i got my passenger side axle halfway out of the brake place and now i cant get it back in or the rest of the way out, i tried pounding on it with a hammer and everything and it doesnt budge.
December 18, 200817 yr Hey Yo! check this thread out, it may help with your troubles. Axle Replacement for EA Series Cars
December 18, 200817 yr Are you trying to remove the front or rear axle? Do a search, there is a really good write-up here somewhere about how to do this the right way and rather easily at that. Its pretty easy to make a simple process turn into a royal B*tch by doing one step wrong or missing one little detail. -Bill
December 18, 200817 yr Hey Yo! check this thread out, it may help with your troubles. Axle Replacement for EA Series Cars Damn, beat me to it -Bill
December 18, 200817 yr Author I checked it out and it is all good info but i know how to get it out it just seems like it is stuck in there
December 18, 200817 yr Did you follow all the steps in the order you were supposed to? If so, you might have damaged the axle and caused it to bind and lock up in the wheel bearings. Did you take the knuckle out of the car to remove the axle? Its easier to get it out that way. -Bill
December 18, 200817 yr Hey.. another Kennewickian! I hope you aren't working outside Try these PDFs: http://www.pixogen.net/usmb/87 GL Axle Shaft Assembly - Service and Repair - Removal and Installation.pdf http://www.pixogen.net/usmb/87 GL Axle Shaft Assembly - Service and Repair - Disassembly and Assembly.pdf edit: I should refresh before posting.. haha.
December 18, 200817 yr Author Yeah, i got the other side in and out just fine and this one just doesnt want to move
December 18, 200817 yr I dont know if you have access to a donor car but if you need to have it done asap, I would remove the knuckle from the donor car and press in your new axle in that then install that on the car youre workin on, then deal with the headache you have now later. Otherwise get a bigger hammer and beat harder, just dont mess up the knuckle. You will prolly want new wheel bearings on that knuckle after this too :-\ -Bill
