Is it possible to retrofit steering wheel on MY95??
Is it possible to retrofit or maybe direct swap of the steering wheel on MY 95 legacy with the one from MY 97 legacy? The 97 legacy has a good leather covering.
The style of the 95 is different than the 97, so I guess the airbag will be swaped as well.
Any advice???
Thanks
OK....so I asked about this.
The splines on the steering shaft should be the same, so I wouldn't worry about that.
Pull both airbags and check their impedences with a meter. If they are both the same, then, with the battery disconnected, simply swap the connectors from your 95 airbag onto the 97 airbag. Problem solved.
