Front hubs and disk upgrade for 1400 Coupe
Front hubs and disk upgrade for 1400 Coupe.
will some leone Ventlated Disks, brakes and Front hubs fit on to a 1400 GSR with out much Hassel?
Thinking it be nice to have much better brakes.
Also another Question do EA71 EA81 and EA82 Brake pads all fit each other?
Curious about the vented disks too.
As for pads the EA63/71 is different over here.
I do know the pads are different
I don't see why the EA81 vented rotors and calipers won't bolt up. I know they do on the '77-'79 cars.
well quite a while ago i took the parts brakes off my old 1400 GL coupe and it looked like they wouldnt fit the leone capliers or disks on there.
But would the hubs, brakes, cvs etc fit on? I dont want to take the ones of the GSR untill i know they Would fit.
also another question would 1986 GT leone coupe front wheel drive rear disks fit on?
Edited by kiwi subbie
I'm not too sure about the pre '77 models but the post '77 models can accept the rear disc brakes but part of the trailing arm needs to be ground down a bit for one of the bolts to fit in there for the caliper. I know for a fact that the EA81 vented rotors and calipers will bolt to a post '77 as I had done it. I then upgraded to the EA81 lower control arms as well but I had to make my own strut rods from round stock. If you can get pics of the way the 1400 is set up, I might be able to help a bit;)
