February 2, 200917 yr Has anyone built an oversize tank for a Brat or installed an aux. tank in one? I'm thinking about putting all that empty space under the bed that would be foot wells in a hatch to good use. I'm curious if anyone has been down this road before and has any pointers. Thanks.
February 2, 200917 yr If your brat is lifted, you can put a larger tank from a FWD vehicle in there. IT is 2 gallons bigger, due to no hump recess for a rear diff. If you lifted yours, the diff will clear the non humped fwd tank.
February 2, 200917 yr i have had 2 brats that the stock tank rusted out. i put aluminum fuel cells from summit against bulkhead and removed stock tank. i would get fuel cell and install fuel switch to switch between 2 tanks. there are electric and manual swiths, i would use manual for easy use.
February 2, 200917 yr Author i have had 2 brats that the stock tank rusted out. i put aluminum fuel cells from summit against bulkhead and removed stock tank. i would get fuel cell and install fuel switch to switch between 2 tanks. there are electric and manual swiths, i would use manual for easy use. Did you put it on top of or under the bed floor?
February 2, 200917 yr i would think put it underneath, where would you put the dogs if otherwise. Did you put it on top of or under the bed floor?
