Wirebrush Posted February 2, 2009 Share Posted February 2, 2009 Has anyone built an oversize tank for a Brat or installed an aux. tank in one? I'm thinking about putting all that empty space under the bed that would be foot wells in a hatch to good use. I'm curious if anyone has been down this road before and has any pointers. Thanks. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted February 2, 2009 Share Posted February 2, 2009 If your brat is lifted, you can put a larger tank from a FWD vehicle in there. IT is 2 gallons bigger, due to no hump recess for a rear diff. If you lifted yours, the diff will clear the non humped fwd tank. Quote Link to comment Share on other sites More sharing options...
lostbrat Posted February 2, 2009 Share Posted February 2, 2009 i have had 2 brats that the stock tank rusted out. i put aluminum fuel cells from summit against bulkhead and removed stock tank. i would get fuel cell and install fuel switch to switch between 2 tanks. there are electric and manual swiths, i would use manual for easy use. Quote Link to comment Share on other sites More sharing options...
Wirebrush Posted February 2, 2009 Author Share Posted February 2, 2009 i have had 2 brats that the stock tank rusted out. i put aluminum fuel cells from summit against bulkhead and removed stock tank. i would get fuel cell and install fuel switch to switch between 2 tanks. there are electric and manual swiths, i would use manual for easy use. Did you put it on top of or under the bed floor? Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted February 2, 2009 Share Posted February 2, 2009 i would think put it underneath, where would you put the dogs if otherwise. Did you put it on top of or under the bed floor? Quote Link to comment Share on other sites More sharing options...
