Legacy Outback Fog Light Replacement
FogLightKing on EBay sells a 5" Fog Light that will work in the outback. I ordered the one listed and it showed up as a 4" light which was to small for me.
I emailed them back and they said no problem, we have a 5" LED Foglight.
I got them today and bolted one up to a spare bracket I had. I had to bend or cut the corner of the new bracket but other than that its straight forward.
I also found that if you save the old bulb, you can cut it back to just the connector and there are the two connectors tabs which you can connect the new fog light to and seal up. That way you can keep the stock Subaru Wiring.
I have not installed it yet, but it looks like a good fit. $60 for a set.
