March 30, 200917 yr How important is it to run a oem temp sensor? I really wanted to try a temp sensor and got one from a local parts store. It says made in italy. I am noticing my fuel economy is not nearly as awesome as it was before I changed the sensor. Is it possible a leaking oil breather line could create a noticeable fuel economy issue to? Can I try using my temp sensor from my n/a 93 legacy on the 94 legacy turbo? The one I put on the 93 was very recent and OEM. Any input would be great.
March 30, 200917 yr I'd recommend using OEM sensors. Yes you can use the OEM sensor from your non-turbo engine. They are the same.
