oooo Posted April 25, 2009 Share Posted April 25, 2009 Will camber bolts for a 2002-06 wrx work on 97 legacy outback struts? The camber bolts I can find for the legacy outback struts only adjust +-1.75 degrees but I found some camber bolts for wrx struts that adjust +-3.00 degrees. Link to comment Share on other sites More sharing options...
subaru360 Posted April 25, 2009 Share Posted April 25, 2009 I believe they will. I have both a wrx and an outback here and they look identical. You can put the aftermarket bolts in both holes to get even more adjustment. Link to comment Share on other sites More sharing options...
oooo Posted April 28, 2009 Author Share Posted April 28, 2009 I thought it wasn't safe to have camber bolts in both the upper and lower on the front strut Link to comment Share on other sites More sharing options...
