May 5, 200916 yr picked up another engine this one is a EJ 2.2 with single port exhast got the y pipe with it my question is , is the blocks the same and can I put dual port heads on it? also wich engine will have more low end torque ( thinking offroad crawling engine) can I mix the parts for more lowend torque? thanks Guys Scott
May 5, 200916 yr Blocks are interchangeable. Single exhaust port engine actually has a better low end if you ask me. It is just more powerful all toghether, seemingly, and features roller rockers:grin:. You may want to go back to the earlier heads if that 2.2 is later than 97 (you don't want an interference timing belt setup on an offroader). If it is a 95 or 96, you are golden.
May 5, 200916 yr Author Single exhaust port engine actually has a better low end if you ask me. . anyone else support this thought ? I remember on the old VW bugs the older simpler engines seem to have more lowend , Ill have to look into what I got thinking this engine should get a carb and go in a light sand/woods buggy SJR
