May 19, 200916 yr Ok i did my thing and used the search function to no avail. How do you remove the front bumper on ea82 cars. 1988 DL to be exact.
May 19, 200916 yr big log chain, find a tree, really big tree, tie around tree, wrap around bumper, floor it......hang on tight. or zzzzzzzzz or.....removed one from a Brat and a Legacy, loyales arent in my brain of super powers if its like the ea81, there will be a bracket on each side, with a couple bolts into the frame rails. Also, there will be a hidden side nut for the bumper to fender on the edge. dont forget to unplug the marker light sockets.
May 19, 200916 yr 2 bolts on both sides of the unibody. drivers side is under the battery, passenger side is under the emissions cylinder thing. First unplug your turn indicators and plug them into the side markers. bolts are welded to the bumper so you don't need to keep them from turning
