May 25, 200916 yr Some time ago someone replaced the driver side doors on my 84 offroad wagon.They had rusted through the bottom edge, and then had aluminum siding riveted to the remaining metal to cover the holes.A buddy gave me a parts car that was pretty straight. So I took the driver side doors off as well as the right front fender because mine was smashed/MIA. The problem is that both doors off the parts car need some work.The driver's door needs the linkages hooked up so the outside handle works,and the rear door needs the glass replaced. How do I pull the trim pieces off of both doors to get to the internals without breaking stuff (doors are manual windows)? Also what is the best way to change the change the glass in the rear doors of a wagon?Thanks in advance,Just wish it wasnt so blooming hot outside..
May 26, 200916 yr So pretty much all you need to do is remove the door handles on the interior and the window rollers. If you have speakers, remove the face plates, and any armrest/pockets. The interior trim is fastened on by little plastic brads, if these break its only gonna cost a buck or two to replace them at any auto parts/ hardware store.
May 26, 200916 yr Author I figured it out.I wasnt sure how to get the window cranks to come off until I found the little pins...
