setting the factory radio
how do you do it. this thing has been blinking 12:00 since we got it. i cant figure it out. its a am/fm cassette. it is a factory radio.
Subaru has used several different OEM radios. Which one do you have? Can you take a digital picture, and post it here. If I see a picture of the face plate, I prolly can tell you how to set the time.
it is a panasonic. here is a pic of it. i had assumed it was a factory radio. maybe i was wrong.
Yes, it looks factory, just that Panasonic keeps changing radio models. I have both a 98 and 99 Leggies. Both have factory Panasonic radios, that are different from each other, and neither look like yours, still there are similarities, so here are my thoughts..........
Judging from your picture, I would try to set the time by pressing in, and continue holding in, the button marked display. While continuing to keep the button pushed in, after about 5 second, press either one of the radio station "tune" buttons. I am thinking one tune button will advance the clock time setting, the other button will retard the clock time setting.
If this doesn't work, while continue to push in the display button, try pushing other buttons in. I have one radio that uses the station preset buttons to set the clock, while the display button is depressed.
Yes, it is frustrating, just like setting the correct time on a digital watch. If you keep pressing buttons, I bet you will be successful.
Edited by Rooster2
additional write up info
thank you that worked this time. i thought i had tried that before. i had almost given up on setting it.
