Lift kits
http://subarugllifted.webs.com/liftkits.htm
Putting up the 2.2 swap this weekend lol
Good Start, bub!:D
Question: On the EJ 4" lift. If I already have OB struts then would it be 2"blocks for the struts and then standard gig for the rest? I know, stupid ?, but I'm looking to get serious about a proper lift here in a couple months.
  • Replies 187
  • Views 46k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
On the EJ lift, it should also work with an EZ30, right? I assume this based on it it working with a BAJA, since they came with EZ30s, and so did outbacks... like the one i have, and bajas are basically outback's with a truck bed and stiffer springs?
2inch yes I am lifting a forester I will take lots of pics
Good Start, bub!:D
cool. look forward to seeing your work.
I am working on a 2 with a friend but a four would be go if your interested I would say 500 right for start because it will need a steering extension
What is your price for the 4" EJ lift (I have a 2000 Outback)?
Have you installed an of these yet?
500 on the kit I am in the works of a 2inch but a 4 can be done let me know if it is in your range and I will design it
I have a 99 Legacy L sedan. I already have Outback struts on it, so I would be looking at a 2" lift that includes 2" blocks for everything, not just the strut tops, and obviously a steering extension to work with the 2" drop. Can you pm me a price on that? Thanks
um 350 sounds good 99 legacy that should look pretty cool
Hey dude, can you supply a couple 4" lift blocks for an ea82 trans cross member? The rest of the wagon has been lifted with 4" 1/4 steel tube..what do you have?
Thanks, Mark
hey i have an 03 baja and want a 2in lift can you help me out ?
ive thought about sjr's 4in lift but i dont like the fact i have to modify my steering so i think 2 in lift blocks for the front and back would be better
do you know any one that could make some
i could probably make the rear my self but not the front
Hey dude' date=' can you supply a couple 4" lift blocks for an ea82 trans cross member? The rest of the wagon has been lifted with 4" 1/4 steel tube..what do you have?
Thanks, Mark[/quote']
6 blocks 2x4 with bolts 50 bucks Ill check shipping
100 dollars yes I make the strut tops for both rear is super easy if you want to do your self not brain science lol
I could build you a 3 inch and sen you the steering linkage to
400 dollars
I just finished a forester a week ago
400 dollars
Looking for 2 1inch square lift blocks for ea82 with the holes predrilled and bolts to go with. Price plus shipping to 50266. Also the car has a 2 inch lift already. Would it be beneficial to me to go 2 inches on this as well or is that to extreme and i would need to extend steering arm and stuff like that.
Sorry these are the ones that go under the engine crossmemeber.
Edited by The Dude Abides
Yo have a 2 inch already correct
anything that pulls the engine crossmember down will require a steering extension
Even just 1 inch. Yes i have the 2 inch already.
You know you dont have to drop the crossmember but it you want to I have some made already you will need an extension to
I didnt really want to mess with the extension. There have been some who have said you dont need the extension. I know you dont need the 1inch but i noticed the cv shaft destroying itself rapidly with it being at that extreme angle. I just thought 1 inch would ease some of the stress off of it. Hell maybe i should do 2 inch since i want 3 inch strut tops at one point.
I have a friend running 2 inch crossmember and 4 inch strut it is doing pretty good
Are these axles the ones ran when it was stock this could be the problem since they ore ran at a different angle now they are going to have problems when you buy new ones they will be use to running at the angle of the lift remember that the geometry needs to be good to if the car is still off camber it will pull the axle out a little more.
But I can send you a extension and blocks if you like
Most people who run ea82s (from what i read). If you run a 3 inch lift you run a 2 inch crossmember blocks to reduce the angle and you need a stearing extension. If you just run a 2inch lift you need none of this but i guess i thought running 1inch cross member blocks would cut down the extreme angles of the front struts a bit. And since it wasnt any more then an inch i would be ok with no steering mods. How much for the blocks. But let me double check my hypothesis.
no worries I just dont want you to overthink it is all 60 plus shipping
