2007 Outback Sport Evap problems
I got a 07 sport at work that was hit in the passenger rear quarter panel. Body work was done, I dont know who did it I cant get an answer on it so I can't talk to the tech that did the work to find out of they cut the harness going to the evap canister system.
I'm having a CEL code P0448 that I cant get rid of. I've rewired the harness to get away with any shorts in the wires. I've tested ohms of the wires and have continuity through all wires up to infront of where the damage is. I cant find a good diagram on alldata or mitchellonline that show that system and wiring in detail. I tested the connectors at the sol. and I get 26 ohms which from what i've been read and told, 20-30 ohms is within spec for a sol that is ok.
From what I can tell by looking at it the vent sol. is located built into the evap system correct? and the purge control sol. is the one that mounts above the evap box?
I need to get this fixed, and I'm looking at buying another evap canister, thinking that the short is on the sol inside the box.
what else would cause p0448 other than a short in the wiring? Someone else had the hoses routed wrong and I replaced the to the best I could tell by looking at older cars. I need a diagram of the pin connectors for the vent sol at the ECM so I can test for power/grounds. Can someone help me out with this? Thanks in advance
