July 5, 200916 yr Do I need to put a sealant between the pump and the backing plate on oil pump? I will put loctite on the screws which hold on the plate. Thanks!
July 5, 200916 yr No sealant on the pump cover, Gray RTV on the oil pump housing to engine block. I let it set 24 hours to ensure its cured.
