camroc14 Posted July 28, 2009 Share Posted July 28, 2009 K so here's the deal. Bought this 90 legacy with an EJ22 FWD for a great deal cause the guy said the O2 sensor was crappin out. well i looked into it more and found out it wasnt the O2 it was the Fuel Pump. it would stutter and almost die if you gave it too much throttle goin down the road... and after i replaced the pump it worked like a dream. its got a 170K on the Odo. So here's what is happening. it worked perfectly, and i mean without evenin a stutter... then one day i drove down the gas station to grab somethin and when i came back out it wouldn't start at all... like it would roll over forever, and there was spark, and fuel... but just NOTHIN ignighting. so i had to have my friend give me a rope tow back home down the street. couple days later i try it again and it works like a dream again. no problems. NEXT DAY NOTHING. same thing as at the gas station. and that was like a week ago and it hasn't given me anything since. What else should i be lookin at here ladies and gents? Quote Link to comment Share on other sites More sharing options...
ericem Posted July 28, 2009 Share Posted July 28, 2009 Fuel pump relay or ignition relay, OR maybe not even these at all. Maybe its a dead ECU coolant temp sensor!!! Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted July 29, 2009 Share Posted July 29, 2009 Could be coolant temp sensor. Probably wouldn't hurt to replace it if it hasn't been replaced in a while. Regarding the pump, I'd check your ground for the pump. Quote Link to comment Share on other sites More sharing options...
