August 24, 200916 yr i have a '96 legacy awd wagon, brighton edition with a 2.2 and automatic. the roads in my city are awful and while replacing a ball joint, tie rod end and wheel bearing on the left side, i remove a broken part of the coil spring. i also noticed that both ends of the removed part were jagged, so it's been broken before. the wrecking yards want to sell a complete strut to me and there don't seem to be any available aftermarket. the dealer is not an option as dealer parts here in Canada are a lot more than in the U.S. there is one wrecker here that i might be able to talk into selling just the spring to me. unfortunately, the subaru he has is a '91 legacy sedan. does anyone know if this will fit? i don't want to put a lot of money into this car as i want to sell it and upgrade to another subaru. any help is appreciated. mark
August 24, 200916 yr You might check the Subaru Recall, these springs were known to break in salty road conditions. I've tossed many of these out.
August 24, 200916 yr Author Thanks for the tip. I'll give that a check but think that the dealer may laugh at me..... it's a 13 year old car with 310,000 kilometres on it. back to my first question if the recall tip doesn't work. anyone know about the interchangability of the springs? mark
August 26, 200916 yr Author been to the dealer. they said that the recall was only for outback! so my original question... will the front coils from a '91 legacy front wheel drive sedan fit on my '96 awd legacy wagon?
August 26, 200916 yr They will probably fit, but I wonder if the spring rate is the same for a sedan and a wagon. I am prett sure I have a set of springs that will fit and are off a wagon. Let me know if you want me to check for you.
