subiekid Posted March 14, 2004 Share Posted March 14, 2004 I just pulled a carbed motor out of an 85 GL wagon, resealed it and put it in my carbed 87 GL wagon. Now that it is in and running, it seems like it's really low on power and it's sputtering quite a bit. Other than that, it runs good. Thanks for your help!!!! Scott Quote Link to comment Share on other sites More sharing options...
subiekid Posted March 14, 2004 Author Share Posted March 14, 2004 bump Quote Link to comment Share on other sites More sharing options...
Danbob99 Posted March 14, 2004 Share Posted March 14, 2004 umm, no it sounds kinda obvious, but how bout your cats? can you get your rpm's up in neutral? Quote Link to comment Share on other sites More sharing options...
skeet Posted March 14, 2004 Share Posted March 14, 2004 What all HAVE you checked? That leaves out the obvious suggestions like clean the carb, adjust timing, adjust idle, pray to satan, fuel pump, ect. Quote Link to comment Share on other sites More sharing options...
torxxx Posted March 14, 2004 Share Posted March 14, 2004 fuel filter Quote Link to comment Share on other sites More sharing options...
subiekid Posted March 15, 2004 Author Share Posted March 15, 2004 There is nothing wrong with any mechanical aspect of the car (I.E. Cats, fuel pump, etc) It has something to do with the motor. The carb is brand new so it's fine, timing is good, idle is fine. I'm leaning towards a vaccum (sp?) leak somewhere but would that cause it to run poorly? Thanks! Scott Quote Link to comment Share on other sites More sharing options...
subiekid Posted March 16, 2004 Author Share Posted March 16, 2004 bump Quote Link to comment Share on other sites More sharing options...
