nw_david Posted April 19, 2008 Share Posted April 19, 2008 so i snapped a timing belt yesterday, and am having some real troubles getting the cams correctly aligned to the crank. i've been doing the routine of: -distributor side cam pin straight up -put the crank to the whatever degrees of the timing -put that sides belt in -turn the crank over once, so the cam opposite -put the non-distributor side cam pin straight up -put in the belt no luck please help, what am i doing wrong? Quote Link to comment Share on other sites More sharing options...
TomRhere Posted April 19, 2008 Share Posted April 19, 2008 http://www.economysuperstar.com/milesfox/subaru/service/timingbelt.htm Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 19, 2008 Share Posted April 19, 2008 sounds like you are using the wrong mark. \use the ||| mark, not the 0 deg when lining up the crank itself Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 19, 2008 Share Posted April 19, 2008 Yeah, you're using the wrong marks. Don't use the numbered TDC scale. Rotate the eninge clockwise another 90 degrees and you will see three lines Looks like this: l l l Use the center of those 3 lines as the mark. Quote Link to comment Share on other sites More sharing options...
nw_david Posted April 19, 2008 Author Share Posted April 19, 2008 wow, im an idiot. im gonna go finish it now thanks Quote Link to comment Share on other sites More sharing options...
nw_david Posted April 19, 2008 Author Share Posted April 19, 2008 1st try, thanks for the help Quote Link to comment Share on other sites More sharing options...
