EJ25 Piston Removal
4 replies to this topic
#1 Durania
Durania
    Elite Master of the Subaru
  • 3,119 posts
  • Crossville, TN
Posted 16 January 2010 - 03:29 PM
I have an EJ25 shortblock that I am wanting to pull the pistons out of. I already have the oil pan off. How do I go about pulling these pistons out and will I need any special tools?
#2 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 16 January 2010 - 08:06 PM
A pair of long nosed needle nosed pliers to remove the pin clips. Then a slide hammer to remove the wrist pins. I have heard of others using different things to get them out but the slider is the correct tool from Kent tools.
#3 Durania
Durania
  • 3,119 posts
  • Crossville, TN
Posted 16 January 2010 - 08:21 PM
Not really wanting to disconnect the piston for the rod. Would like to keep it all together as one piece.
#4 Qman
Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 16 January 2010 - 09:38 PM
Not designed to come apart that way. Pull the pistons, seperate the block and remove the crank and rods.
#5 Durania
Durania
  • 3,119 posts
  • Crossville, TN
Posted 16 January 2010 - 09:48 PM
Got ya, thanks. Looks like I need to invest in some monster Hex heads.
