fitting hitachi electric choke to weber carb
3 replies to this topic
#1 zuki1100
zuki1100
    New User
  • PipPip
  • 12 posts
  • Christchurch, New Zealand
Posted 16 October 2010 - 02:56 PM
Hey all,
I've bought the 32/36 weber which was a DGAV (Aqua or water choke) but intend converting to electric choke.
Just wondering if anyone has tried swapping or modifying the hitachi electric choke to fit the weber and what advice they could share in doing so.
Have priced the weber electric choke to fit and a local guy wants to charge NZ$120.00 for the part only (imported ex-UK). I've got a spare Hitachi Electric choke carb, have removed the mechanism and aside from needing an adaptor plate to fit to the weber the operation looks almost identical. So chances are high that this should swap over and work as required on the weber.
Thanks in advance for any thoughts/help/suggestions.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 22,049 posts
  • Portland
Posted 16 October 2010 - 03:13 PM
Use the water choke - it's better anyway.
#3 zuki1100
zuki1100
    New User
  • PipPip
  • 12 posts
Posted 17 October 2010 - 01:59 AM
Great, thanks for that, certainly seems to be lots of the DGAV variety around our way in terms of parts should they be needed.
Much appreciated.
#4 GeneralDisorder
GeneralDisorder
  • 22,049 posts
  • Portland
Posted 17 October 2010 - 02:40 AM
If you give it some thought.... the water choke actually tracks engine temp. The electric choke simply tracks with the choke heating element which depends on how long it's been on - it doesn't know if the engine is running or just the ignition is on.... etc. And even if you hook it to a tach-signal controlled relay it's still not tracking engine *temp* just whether it's running or not.
The only drawback to the water choke is the extra hoses and properly routing them.
